Maybe I should have posted this in general. I have a little bit of hum and buzz at high volume with FPIII in system but it isnt the FPIII.
I need to give some background. This is with TT set-up. TT - Seduction - FPIII - Crack. I was initially running the TT (Rotel RP900 Rega 2 clone with Rega RB250 arm). through a Hagerman Cornet phono stage directly into Crack. There was a bit of hum at mid volume and higher. I re-wired the RB250 and probaly dropped the hum 10db or more. It could only be heard with Crack volume turned up past 3 o'clock and was pretty low level, not heard over music. I built Seduction and the hum was still there but lower level still at same volume knob setting on Crack (Cornet had 4 db more gain than Seduction).
With FPIII added to the signal chain and the attenuators set mid-way (about unity gain), the hum level is the same with volume on Crack turned up to the same level but there is a little bit of buzz as well. Again, low level, cant be heard over music. Of course, with gain added by cranking up FPIII a little bit, the level increases accordingly for the same volume setting on Crack. I shorted the inputs of FPIII and it is quiet. I shorted inputs of Seduction and it is quiet. So, the turntable is the culprit (and not unusual I would think as there is a little bit in the main system as well at high volume with a different tabe and componenets).
If youve been patient enough to bear with me, here is the question ... where does that little bit of buzz come from if Seduction, FPIII and Crack are all quiet? Again, there is that low level hum from the turntable. But im wondering where the buzz comes into the equation. Knowing the little that I do know, it's usually indicitive of a ground "issue". But again, components are quiet with inputs shorted which seems to point the TT as the source, but still, no buzz without FPIII in the chain. So Im thinking probably a ground potential (if potential is the right word) between the TT, Seduction and FPIII and maybe Crack as well. Not a "fault" of/in any one component, Rather the combination of all of them, with the TT seemingly the ultimate source of the issue. Also, I can really induce the buzz by touching the cartridge clips. I can live with this as it's low level and cant be heard over the music at all and is also really only present at volume levels I would only occassionally listen at. But if I could get rid of it without too much hassle I'd try it. And ideas to try, where to start? I havent tried anything yet because Im not sure where is best to start.
