I put a spiffy green 3v panel mount LED in my nixie clock recently that I like the look of. I noticed they make them in a 6v version as well, which I figure should work pretty well on the DC heated kits.
www.dialightsignalsandcomponents.com
I personally have left on both my Mainline, and Eros 2. Between the tube shields and the chromed tops of the reg tubes it's been easy for me to forget (unlike the Crack variants with bright 6080s). Any concerns with wiring in one of these 6v LEDs to the 6.3VDC heater connections? What would be the ideal place to hook them up?
Less critical (I can usually see some glow on the 6CM7s), but I'd also like to set one up on the BeePre2...if possible. Looks like the 6.3v line on that is AC but seems to be a possible 6.5vdc tap elsewhere on the voltage checks.
Thanks as always!
620 LED PMI 8mm Green 6 VDC
Dialight Signals & Components is a leading provider of LED indication for PCBs, panels, traffic signals, vehicle and rail lighting. Browse our products, find a distributor, and contact us today.
Thanks as always!
