Speedball issues [resolved]
Good call, I swapped out the LEDs and now they light. The right channel still turns on first though (immediately after plugging in). I get
250 on B, 130 on OA, 150 on OB and 0 on G.
Oddly enough, I get 0.6 ohms across both resistors in the headphone jack. Might that have something to do with it?
I've tested all the other circuit elements, and everything else seems to be working properly.
There's either a miswire from the board to the circuit, or there's still a toasted part in your kit.
The resistors on the headphone jack will read 0 ohms with nothing plugged into the jack; that's normal.
Post some photos of the top and bottom sides of the PC board, as well as the build as it sits now.
Also check the resistance of the R1 resistors on the big C4S board.  You can measure their values in circuit.
All joints https://imgur.com/a/tEgLPw1.
R1 resistances are both 32 ohms, and the resistances of every single other resistor is within 10% of what it should be (except the ones in the headphone jack). Base to collector and base to emitter are between 655 and 740 on every single transistor, probing the joints from the underside of the circuit boards. Diodes are all around 500-600 on the transformer.
All 5 capacitors charge (20KOhm setting used to check). RCA resistances are 92 and 99 KOhms (L and R respectively). Tubes glow on both sides, and neither of them seem particularly bright or hot.
I know one of the TIP50 transistors looks a bit janky and seems like it has a poor mechanical connection, but the leads won't fit in the cutouts, and the resistances from the bottom seem about right. How likely is it that the tubes or the transformer have gone bad? Thanks again for your patience.
Droo -
If that were my amp I'd do three things before trying to troubleshoot any resistance or voltage issues:
(1) Reflow every solder joint in the amp by (a) placing the soldering tip so it makes good contact with both the lead and the terminal (i.e., both surfaces to be soldered), and then (b) waiting until the solder suddenly flows like water around, and gets sucked into, the joint. From your pics there look to be a fair number of sketchy joints - too many to circle or list. Even if they're working now, I'd be concerned that they'd fail in the future after repeated heating and cooling from use. PB has said he can reflow a Crack in 30-45 mins. So I figure an ordinary human can do it in under 2 hours.  Even if this doesn't solve your issue, it will help ensure that the amp, once you get it working, stays working for a long time.
(2) Fix the diodes.  You've got all 4 on the same side of the terminal strip. That's a short waiting to happen - either by the leads of two diode making contact or a diode grounding out to the chassis. I'd reinstall them as per the manual or at least insulate them from each other and the chassis (but the latter fix will take more time that simply reinstalling them two-a-side.)
(3) Fix the small 270K resistor in the power supply near the big white 5W 270R resistor.  This also looks a short to chassis waiting to happen.
I figure you could do all of the above in less than 3 hours.  And who knows, maybe that will solve your problem. And if not, it will make tracking it down a whole lot easier.
cheers and good luck, Derek
Most of your work looks good to me. Derek mentions fixing the diodes. I wouldn't necessarily do that. Unsoldering them will be very difficult and putting two back in on the other side will be even more difficult. You could slip some electrical tape between them for a minimal level of protection.
Many of your wires still need clipping with a good sidecutter. Those are about $20 with shipping and tax. It's going to be difficult to get to some of the wire ends with everything assembled. You would have been better off clipping them sooner.
I'm with PaulB when he suspects another toasted part. Tubes and transformer are almost certainly still good. They are robust.
Thank you both so much for the suggestions! I'll definitely try to get better/smoother joints all around and clip whatever leads are still too long. Resoldering the diodes might be a little difficult, but I'll give it a shot, otherwise I'll go with some electrical tape. I want to note that the ones that should not be in contact look like they're in the same plane, but are in fact bent away from each other.
What's wrong with the board itself? At this point I'm very confused, because it doesn't seem like anything on it is broken, but yet it doesn't work. Should I buy a new speedball?
When all the LEDs light up brightly before anything has warmed up in the circuit, the board is not working properly.
You can contact replacementparts(at)bottlehead(dot)com about getting a new big board and associated parts.  You do absolutely need a proper pair of side cutters to trim things down in there too.
It works now, and it sounds great!! However, I'm getting 145 on OA/OB and 250 on B+. Is that a problem? It's dead silent when nothing's playing. I'm using the Raytheon 6080 that came with it if that matters. Thanks!
What are all the voltages on the small PC board?  You should not have 250V of B+.
Can you also inspect the solder joint on the headphone jack where the black wires meet?  Sometimes one is loose there and that will make your DC voltages look a little weird.
The headphone jack joints all look solid. One of the LEDs on the B+ side isn't turning on, but the one after it is. I remeasured the big board voltages, and they're actually OA: 116 OB:125 and B+:215. Little board voltages: OA:84, 1A:215 B/AB:0V 1B: 220 OB:79.
One LED out on the big board is definitely an issue.  Your small board voltages look good.  B+ on the big board and IA/IB on the small board are all wired together.  You can't have different voltages on these board pads without flaky solder joints at work.
Yeah, I think it went out when I tried to get a better joint on the TIP50. I replaced it and am back up to 235 on B+ and 130 apiece on OB/AB. A weird thing I noticed is that if I tap the input tube, I hear it much more distinctly in the left channel.
What's your AC wall voltage?
I strongly suspect your big Speedball board is still not working at all.  The high voltages on OA/OB indicate that the 6080 is drawing nearly no current.
