Can you play a 60Hz AC tone into the amp and measure the AC voltage across the RCA jacks? Then turn coarse and fine switches all the way up, then measure the AC voltage between the ground buss wire at the front of the amp and each of the lower lugs on the coarse attenuator? (you can/should do this with the amp off)
