At page 54 of the manual, for 230Vac (if your voltage is GREATER than 225V AC and LESS than 235V AC section), it says in the first step, "Attach the other end to 44U", and 44U is not mentioned in the following steps (so it is not soldered). Then it comes the power transformer secondary test. I guess the test must not be done with a wire not soldered. Is it a typo so it has to be "Attach and solder" or a step is missing or miswritten ? I quickly go over the other sections and I think this issue exists for all 3 sections: (210Vac, 225Vac), (225Vac, 235Vac) and (235Vac, 250Vac).
