Hi, something shocking just happened. I had previously built my Kaiju up through mounting the C4S boards using .1uf Audyn copper caps between 4U & 32U and 23U & 46U. I did my Driver testing voltage checks and all my numbers came in fine on both boards (IA-511VDC, OA-299VDC, 32U-175VDC 46U-175VDC).
Then in another thread, I found out that I'd need to secure those caps much more firmly to the board, and might have to order a solder pot to feel confident about soldering the stranded Audyn leads and decided to substitute some .22uf 1400vdc Mundorf supreme caps instead because their leads would be easier to solder securely. I confirmed the higher cap rating would work and proceeded to replace the Audyns. So I just resoldered 4 connections, which look fine.
When I was done, I decided I should redo the Driver voltage tests just to confirm I was still good to go. Plugged it in, all seemed fine. The A side board measured the same as the previous test. On the D side board, IA also measured fine, but when I touched my multimeter probe to OA, I heard a load zap and pop and the R1 resistor burnt out (see photos.) Did I do something with my multimeter probe that did it? I checked the wiring on the D side board and it looks correct, and the cap soldering between 23U & 46U looks good.
Any idea what happened? Can I just replace R1 on that board or should I suspect that I damaged some other components?
Any advice on how to proceed would be welcome. Thanks.
