I'm considering painting the silver metal bits of the topside transformers of my S3X a wrinkle finish; likely black. That would be the power transformer bell and the output transformer mounting frames only. Wrinkle paint can require a bit of heating for best wrinkling results, something around hair blow drier max temp, around 170'ish degrees F. Or a bit of a bake in an over at this temp.
I'm confirming whether these transformers - really, only the output transformers - can manage this heat and won't be damaged.
If not, I'll just move on to another plan.
Thanks.
Thanks.
