Currently I am using a vintage integrated Onkyo A10 power amplifier, and I'm thinking about buying a BeePre and bypassing the preamp stage of the Onkyo and just using it as a power amplifier. The input impedance for the power amp stage of the Onkyo is 50k --- is this too high for the BeePre with an output impedance of 500 ohms? (I don't know much about impedance matching, only that you want a factor of at least 10 or 20 times higher, but it's unclear to me if you can have too much of a good thing). I've attached a pdf of the Onkyo spec sheet --- Is anything else I should be concerning myself with when assessing how well these two pieces would match?
Also, is there any reason to suspect that the Eros will have volume issues running through this setup? My phono cartridge is the Clearaudio Maestro, at 3.6 mV output.
