pranabindu
After I soldered terminal 5 of PT-7 A, I clipped the diode leads protruding from terminal 5 and 37U. A piece of clipped lead, about 1/3 of an inch long, fell into PT-7 A in that crevasse that runs between terminals 5 and 10. Turning the unit over to let it fall out did not work, because it seemed to be stuck to the surface. Trying to use thin tweezers to pull it out only jammed it deeper. I can't get needlenose pliers to grab a hold of the jammed lead, and it seems that the more I try the more jammed it gets in there. I don't think it's possible to remove at this point.
Will this cause any problems with the operation of the preamp once I finish building it? What should I do?
Thanks for any help you might be able to provide.
