Hi
Just finished assembling the Eros kit. Measured the resistances and they looked OK and the voltages were close. So I plugged in the CD through a reverse RIAA circuit/attenuator into the Eros and then into a small amp in workshop and out came music! Terrific, or so I thought. I left it playing on repeat for the best part of a day (with the amp off) to start the burning in process. Came back later that day to have a listen, and the channel balance seemed off, with most of the sound seeming to come from the black channel. Did a quick and dirty by measuring the output with the multimeter set to AC while it was playing. The Black channel was jumping between 0.4 to 0.6 V while the red was jumping between 0.2 and 0.3 V. Hmmm! I swapped the input leads, but the black channel was still noticeably louder. I swapped the EF86 tubes around, replaced the 6922 with another one I had, but still no joy. Decided to see just how far off it was, so I pumped in a 1 kHz signal via the reverse RIAA circuit and hooked the outputs to a scope. The black channel was about 0.5V peak to peak. Plugged the 1 KHz signal into the red channel and got about 0.25V, which was pretty much the same as the quick and dirty I did with the multimeter. I rechecked all the components on the 2 servo boards, wetted all joints on the boards with a touch of extra solder, checked and resoldered the tube plugs and each signal path from start to finish and measured the resistances to make sure they were actually what they were suppose to be. Alas, the problem persists. I
