Voltage check problem [resolved]
Hazim_hatta
Hi all,
I recently build crack for my sennheiser. During build, terminal 2,4,7,9 have higher voltage but similar reading of the pair. An a constant hum even without input when tested with headphone.
My input voltage is 225. Here is my DC voltage reading:
1. 95v
2. 233v
3. 0v
4. 234v
5. 88v
6. 0v
7. 135v
8. 0v
9. 132v
10. 0v
Powerline test result is 225v, then I follow instruction in page 26 for 210v to 225v. The official is 240v in my country.
I would recheck that line voltage.  I suspect you have closer to 240V coming out of the wall, and that is pushing things up a bit.
You only have to move one connection of one wire to change to the 225-235V, and I would suggest giving that a try. Just move the red wire from power transformer terminal 17 to power transformer terminal 18 and recheck your voltages.
I fixed that, the dc voltage drop to 215 - 220 v rage for terminal 2,4 and 125-130v for terminal 7,9
*change to 235-245v setting, the dc voltage on 2,4 reading drop to 195-200vdc and terminal 7, 9 drop to 115 to 120vdc range
I would leave it set for 235-245.
With no source connected and the volume pot turned all the way up, there will be noise.  Is there noise with the volume control turned all the way down?  If so, you likely have a loose connection or a solder joint or two that need to be reflowed.
With volume all way down, there still hum. Is there certain location that i need to look out for?
And should I proceed with the speedball?
If it sounds more like a buzzing noise, that's typically a loose power supply capacitor.  If it's a deep hum, that is more likely to be loose hardware or a loose solder joint.  You can also post some build photos and maybe we can spot something.
For starters you need to twist the green heater supply wires and braid the red, white and black signal wires from the RCA jacks to the volume pot. The instructions are detailed in the assembly manual. Either of those not being properly dressed could be a reason for excessive hum so they should be corrected first. Once that is done if the hum persists we can start to look at other possibilities.
I have attached a photo of a partially complete Crack amp I am currently assembling so that you can have an idea of what the wiring layout should look like.
I see a 22 ohm resistor in your power supply that is the wrong value.  Putting the correct parts in here will fix the high B+ issue that you had before and drop the noise floor down closer to where it should be (which will further be lowered by twisting the green wires and dealing with the unbraided input wiring).
Did you receive that 22 ohm resistor in your kit? If so we may have sent the wrong part and we will replace it. Please check the value of the other large white resistor too.
LEDs not lighting up suddenly will mean that the DC voltages on terminals 1-10 are no longer correct and you would want to post those numbers in order for us to help you determine what has gone wrong.
You will definitely want to get some 270 ohm 5W resistors in there, feel free to drop an e-mail to replacementparts(at)bottlehead(dot)com and we can get some sent to you.
