Pflugshaupt
First of all, please excuse my ignorance, I just started to get into tubes about a year ago, built two bottlehead kits (crack w/speedball and reduction w/integration) and now I'm fooling around with tubes, eager to learn more about how these things work. I have a question about using different tubes with reduction + integration using octal adapters of various kinds.
I'm just trying some things coming from modding my crack to use a 6SN7 tube. So just for fun I put two 6SN7 into the reduction + integration and was frankly amazed it worked. However of course gain is quite low as 6SN7 have a mu factor of 20 while the 6992 in the reduction have 33. So with my noob approach I started looking for some other tubes and I really like octal sockets for some reason. That's how I found out there are 6C8G tubes somewhat similar to 6SN7 that have a mu factor of about 36 and use the same 300 ma/6.3v heating current the 6992's use in the reduction. I couldn't resist trying some of these in the reduction... but as you probably have guessed by now - it doesn't work - I get heavy distortion and low output. Now my big question is what is the main reason for this and would it theoretically be possible to adjust the reduction + integration circuit to make them work?
From reading the sheets I think the big difference between the two types is the plate resistance/current. So secretly I'm hoping I could somehow lower the current somehow and that would magically make things work. But it's of course quite likely I'm looking at this the wrong way so feel free to smash my hopes
For reference these are the numbers I looked up (maybe others are more relevant?):
6992 <-> 6C8G(VT-163)
heater voltage: 6.3 V <-> 6.3 V
heater current: 0.36 A <-> 0.3 A
plate vmax: 130 V <-> 250 V
plate current: 25 mA <-> 3.2 mA
plate dissapation: 1.8 W <-> 1 W
plate resistance: 3 kOhm <-> 22.5 kOhm
mu factor: 33 - 36
mu factor: 33 - 36
