Moderator
"If it sounds good, it IS good" remains true, and I can't argue with it.
But drawing conclusions is a different issue. For example, a 12AT7 will have a higher plate voltage, driving the 6AS7 to a higher cathode voltage, and (without the Speedball) higher current. Our experiments have shown that increasing the current in the 6AS7 improves the sound - so ascribing the improvement to the 12AT7 by itself would be inappropriate. (With Speedball the current is constant so this effect is less significant.)
The same arrangement would increase the dissipation of the cathode resistor beyond the design condition. With the Speedball, it's the transistor dissipation that would increase. Either way, the components may have a shorter lifetime.
Both of the above are caused by the direct coupled design - sounds good but it's just less robust than cap-coupled topologies.
