Let's start a topic to share experiences with tube rolling in the Stereomour II.
Please share your opinion on different tubes in SII!
SI users are welcome to share aswel!
I'll try to keep this startpost up to date with what tubes to use in SII.
The list of tubes to use in the drivers seat:
12AT7(W)(A)(B)(C)
ECC81
E81CC
ECC801S
6201
6060
CV455
CV4024
A2900
TS65
B309
M8162
7728
6679
Not direct equivalent, optional:
5965 familiy (E180CC = 7062 = CV8431 = 6829 = 6414)
6211
Do note: some have minor electrical differences from ECC81 / 12AT7, but can be used in SII.
The list of tubes to use in the output position:
2A3
5930
VT-95
CV1831
#2A3-40
300B 2.5V (EML (solid and Mesh / Sophia)
! 45 (145,245, 345 etc.)
#The extra power available with these tubes not being used in SII.
! Needs some modification. https://bottlehead.com/smf/index.php?topic=11138.0
EML 2A3 or 45 tubes in SII: https://bottlehead.com/smf/index.php?topic=3054.0
Guarantee conditions: http://www.emissionlabs.com/cd.htm
So. It's ok in a stock SII. If you replace the interstage coupling (0.1uf, 600V) with a paper in oil type coupling capacitor, it will void warranty.
12AT7(W)(A)(B)(C)
ECC81
E81CC
ECC801S
6201
6060
CV455
CV4024
A2900
TS65
B309
M8162
7728
6679
6211
2A3
5930
VT-95
CV1831
#2A3-40
Paul Joppa said:The 6.3v heater winding is rated 1.5 amps.
The 2A3 filament windings are actually 3.15 volts at 5.5Arms. (The high current rating allows for DC heating, which is an optional upgrade for those with extremely sensitive speakers.) In both AC and DC cases, the filaments have small series resistors to fine-tune the voltage.
