benz said:Just one question does the wires in terminal B8L and B7L need to be soldered? I did not solder them cause it's not mention in the manual.
Grainger49 said:[size=12pt]
T1 and T5 should be connected to each other and therefore must have the same voltage on them.
Grainger49 said:B1 and B3 are the result of that half of the tube not turning on.
My message was to the original poster. You could remove every ground wire from the Crack and the tubes would still glow.Grainger49 said:This one?
"Are you 100% sure both halves of the 12AU7 are glowing? If they are, do both your LEDs light?"
We use essential cookies to make this site work, and optional cookies to enhance your experience.
