I'm just not happy with the solder job I did at the headphone jack. It's just such a mess that it's beyond solder wick. I just want to cut it out and start anew.
1. Is there anything to be gained by buying a pricier jack?
Like this:
www.digikey.com
2. Anything to be gained by swapping out the resistors on the jack, like a Vishay Dale metal film? Any suggestions? How critical is the 2.49 kohm spec? What happens if I use 2.7? How critical is the 1/4 watt rating? Is 1 watt OK? How tight should matching tolerance be, 1% OK?
Thx
RS
Like this:
4802.2300 | DigiKey Electronics
Order today, ships today. 4802.2300 – 3.50mm (0.141", 1/8", Mini Plug) - Headphone Phone Jack Stereo (3 Conductor, TRS) Connector Solder Eyelet(s) from SCHURTER Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
Thx
RS
