The LED's on the 9 pin socket can be changed to resistors for troubleshooting. This is not the case for any other LED's in the amp, if you use resistors on the PC boards in place of the LED's, the boards will not work.
470 Ohm resistors can be used for the 9 pin socket LED's. If you find a value in the range of 450-500 Ohms, you'll be OK. Wattage isn't exactly important, 2/100 of a Watt is sufficient.
