top of the 12au7 tube doesn't glow
agent10508
During the glow test of the tubes, only the bottom of the 12au7 glowed while the top remained unlit. The stock tubes provided are labelled Beckman which I believe are rebranded Sylvanias. The main power tube glowed excellently, so should I be worried or is this just a quirk of the tubes provided?
Whether the top and/or bottom glows depends on the position of the heater element inside the cathode sleeve, so if you don't see a glowing dot on the top of one side but you do see it on the bottom of that side, all is well and there's nothing to be concerned about.
