Finally got around to taking some pics of the Ton-O-Fun.
Current configuration:
MQ Iron and C4s upgrade.
Shorting hedphone jack.
Replaced Parafeed cap with 2uf Russian PIO
Replaced the coupling cap with .1uf Russian PIO
Replaced Cpsu with a soup can sized Solen I had laying around
Replaced Cd_psU with some even bigger 24uf motor runs I dug out of the parts bin
The bias caps were replaced with 1000uf Nichicon Muze
The remaining Psu Caps were moved to the center of the amp to make room for the Cpsu and Cd_psu caps and wired back to the stock location with the shielded wire supplied with the kit.
And the heater cap was replaced with a 10000uf Mundorf Mlytic
All signal wire is Mundorf Silver/Gold 1mm with unbleached cotton tubing.
