Prairie Dog
Hi everyone, I'm having trouble with a pair of TJ 2A3 mesh plates I bought from diyhifisupply a couple of months ago, problem was right out of the box, though after several emails back and forth, they seem to think it's an issue with my monoblocks. Here is a partial copy of one of my emails to them:
"I could not set the bias on the tube marked F254 to a value any better than -30V or so, with a plate voltage of 295V. Recommended is -45 bias with plate voltage of 250V. The tube marked F288 can be set to -44V, but this is at the maximum range of adjustment on my amp's bias setting. This gives a plate voltage of about 268 volts."
This is actually the second pair of tubes from them, the first had an obvious defect in one of them, and it took forever to get them to replace the pair, I'm wondering if he is just brushing me off on this pair also? He suggested there are ways to "adjust" the Paramounts to work better with their tubes, but has yet to offer any thing else.
FYI I've been using a pair of Shuguang 2A3Cs for 2 years and they set up beautifully: Vp 250V bias -45V Similar results with Russian variety. So, they've had my money since March, and I'm still not able to use their product.
Any help is much appreciated.
As a sidebar, I built an Eros phonostage a couple months ago: huge improvement in all areas.
-Trevor
-Trevor
