Testing with tubes terminal 7 read 1vdc instead of 170-230
I think its a very old kester. I finished It and Will now use weller Just arrived a couple of drops of the weller were used on this pcb i think when i reflow the soldering yesterday
A very hot iron and low dwell time works well for the boards, but not enough heat will lead to flux building up between the solder joint and what it's supposed to solder, and you can end up with weird issues like this that don't make a ton of sense.  The exception is the LEDs, which have so little ability to dissipate heat that they solder very quickly.
I would reflow every joint on that PC board other than the LEDs.  What you have is not consistent with a transistor failure.
I am cooked as well. Reflow all,still not working. What if i dismantle It almost completely and start from scratch? Will you accept order for a list of components or out of your scope and should buy them locally?thanxs and apologize for not being a good fellow that makes things right First Time.
You can contact replacementparts(at)bottlehead(dot)com about getting a replacement PCB and parts for your Stereomour.  Some 60/40 leaded solder and a soldering iron set to 800+F would probably help too. The old Kester should work well provided it's leaded (not silver bearing).
Thanxs! The solder station Is decent at 65w. Ordered now 60/40 Classic lead no silver. I want to make It working this time. Will check continuity or resistance at each soldering parte. Sent mail to your ref mail to ask offer quote. Cheers
Dont think Will finish this amp. From thursday last week ,when i wrote for replacement parts,nobody took care of me.  Not what i expected, honestly
