Karl5150
Having rebuilt several of my BH kits and built a couple of other kits that required purchasing the components, I have more often than not ended up with terminal strips that were difficult to get the solder to flow and stick to, especially the lower holes. I use a Weller station with plenty of heat and a wedge tip.
For my current build I lightly scuffed the strips with 1500 grit and wiped them down with 91% alcohol. I still ended up with a couple failed resistance test points that fell into line after I touched-up a connection point where the 3 leads were soldered to each other but not conducting to the lower hole.
What brand comes in the BH kits or have others used with success? This hasn't been a problem on the original builds.
