ALL212
Member
I've been collecting parts for a couple weeks - have enough around to start.
But first I'd like to state this. I don't upgrade components in the Bottlehead kits because I need to. What they come with works just fine. I upgrade because I want to, it adds to the challenge of putting this together and I do have some psychosis that causes me to stray from any given directions
Unless you know that a larger gauge wire will fit you should stay with the wire gauge given. I thought I'd put in bigger ground lines but I couldn't get three 18g wires in the standoffs provided easily. I have a collection of various chassis wire that I've used over the years and will always go bigger if I can. The tranny wire isn't near as big as it appears. It's a cotton covered, plastic insulated 18 gauge. The ground wire is a very nice 20 gauge silver tinned copper with Teflon insulator.
Inputs RCA's are Cardas GRFA-S and the outputs are Cardas CCGR (I'd probably rethink using these :-\ - LOTS of heat to get these soldered in solid.).
I'm not sure if my AC run from cup to switch is going to cause a problem but I thought I'd try braiding these larger gauge instead of the shielded provided. If it gets noisy I'll put something else in :-[.
Tomorrow starts the input wiring.
I'll be adding to this - so let's call this stage 1.
