Stereomour Big Spark, no sound
Samsquatch
Member
So I flipped on my 'Mour a while ago. A big spark came through the top plate and now I have no sound. Did my voltage checks at the shunt regulator mod, I have no power on the A side. No leds lit on the B side of the board when you're looking at it by the B label on the board. B side voltages are good and the other two leds are lit. What is my next step in trouble shooting, or is the next step a fix? All help appreciated
Check the resistance of the 130 ohm resistors in the power supply. If one has opened up, that's a possible indication that something may be touching the chassis plate that shouldn't be.
You'll have to start by replacing those. The most common way for them to blow is by having the 2A3s installed in the sockets improperly.
That did the trick. Sounding wonderful once again. I suspect my teen son was looking around at things and probably miss placed a tube unknowingly. It's okay, he's becoming an excellent guitar player and taking a bigger interest in my listening system. I gave him a lesson in tube rolling and the importance of being aware of tube types and pin types and location. On the other hand, it could have been me, but I don't remember changing or removing tubes between listening for a long time.
