Rocketman248
Member
So I'm in the planning/saving stages of some system upgrades. Getting a new turntable and cartridge in a few months, and I have some questions regarding step up transformers when paired with an Eros. Current setup is an Ortofon 2M Black into an original Eros, which is then fed into a BeePre and Kaiju. In a few months, I'll be upgrading my table to a VPI Prime Signature, and I'm shopping around for a suitable cartridge. On the short list right now is a Hana ML or Lyra Delos.
I know both of those carts will require a Step-Up Transformer, and I do have one that I kind of accidentally bought a few years ago (dumb, unresearched purchase). It's a Phasemation T-300, with 26db of gain, which after some reading, leads me to believe it's a 1:20 ratio.
I'm pretty much terrible at math, so could the wizards here let me know if that's too much gain to be paired with the Eros/BeePre? Will it be ok, or should I look for a 1:10 transformer?
Here's the specs for the two carts:
Hana ML: 0.4mV output voltage. 8 ohm impedance. >100ohm recommended load impedance.
Lyra Delos: 0.6mV output voltage. 8.2 ohm impedance.
