Aural Robert
Finished my SEX amp the other day, and the resistances checked out ok. When I plugged it in for the "smoke test" there was in fact smoke. And a couple of snaps, it almost sounded like the caps were settling in or something. Which I don't remember from any previous build. I turned it off immediately and found a questionable connection of the cap on T11/12 (which interesting enough is where the smoke came from too).
Rsoldered the cap, powered it back up, voltages all seem to check out, except that on some of them where I should get 0 I have a reading of millivolts - is this correct?
I hooked it up and the volume is waaaaay low. I have a set of Paramour 2A3's and Fostex Fe116E horns, and when I swap the speakers from the 'mours to the SEX the volume is less than half. With headphones, I can crank it to the top and it is not loud by any means.
Not sure what to look at as everything seems to be ok. HELP!!!!!! Thanks to the 'bot community in advance.
Aural Robert.
... we have a map of the piano ...
Aural Robert.
