So I just got the Speedball installed, vacuum tubes light up fine, however I don't have sound in the right channel or if I do, its very low volume compared to the left. I noticed that one of the smaller PCB's next to the headphone input jack which has two LED's, only one of the LED's is lighting up, I removed it to make sure it was installed in the right direction which it was and reflowed all of the solder joints on that PCB just for good measure. It still doesn't light up. Could this be the cause of my right channel problem or should I look deeper? I also checked the 2N2222A and 2N2907A transistors and they're installed in their correct positions, so there's no mix-up there if that helps. Any suggestions from your guys or PB on this would be greatly appreciated.
Thanks.
FYI, my Crack has been running fine for the last 2-3 months now before I installed the Speedball.
Thanks.
