Speedball 1 & 7 channel high voltage
Can you remove the small PC board on the offending side and put the 22K resistor back in, then recheck your terminal 1 voltage?
I will give that a try this weekend when I should have some time to work on things.
I'm starting to think that maybe a ground came loose while transporting the amp from my home to my work (have nice pace soldering gear at work). I'll retouch all the grounds this weekend too.
Okay so good news! Looks like I found the bad ground (sounds the same upside down or right side up), not sure exactly where it was I was just touching up a few spots then tested things out and it seems to be good! A1 and A7 are still higher than the other side but are within spec now at least.
It's still recommended to connect the non used pins on the 1/4" Jack to ground correct?
There's certainly nothing wrong with doing this to a stock Crack or Speedballed Crack.
