justinscharber
All,
This is my first post. I have been following the forums for several months as a "guest" trying to learn as much as I can and finally joined the forums.
I completed my Crack build a couple months ago with no issues. I took everyone's advice and waited before installing the Speedball upgrade to learn and enjoy the Crack in it's original state. I'm really enjoying the amp with my HD 650s.
This weekend I completed my Speedball upgrade and seem to be having some voltage problems. My readings are listed below. I'm concerned about the negative voltages I'm getting at terminals 6 and 10. I also measured the voltage rise to the headphone jack during power up; it was 0v to 22v to 0v. All of my LEDs light up. I have noticed that the LEDs on the smaller two boards aren't lit as bright as the rest (larger board and A terminals). I also had someone conduct a visual to make sure they didn't notice any cold solders (although I'm still not ruling that out).
Finally, at a slight risk I plugged in a pair of headphones to see if I was at least getting some sound and I am. Actually it still sounds great. However, there is a very noticeable noise floor; like a constant hiss. I isolated the hiss to the amp by removing the inputs. Even with the volume knob at 0, I still have the same level of noise floor.
Voltages (Required Measured)
1- 75 101
2- 170 179
3- 0 0
4- 170 179
5- 75 79
6- 0 Fluctuates between -(NEG)20 to 0
7- 100 120
8- 0 0
9- 100 118
10- 0 Fluctuates between -(NEG)20 to 0
11- 0 0
12- 0 0
13- 170 179
14- 0 0
15- 185 185
19- 0 0
20- 0 0
21- 206 219
a1- 75 95
a2- 0 0
a3- 1.56 1.54
a4- 0 0
a5- 0 0
a6- 75 97
a7- 0 0
a8- 1.56 1.54
a9- 0 0
b1- 75 98
b2- 170 179
b3- 100 120
b4- 75 95
b5- 170 179
b6- 100 117
b7- 0 0
b8- 0 0
The high voltages coupled with a couple fluctuating negative voltages make me think I have a tube that might be failing or failed. Any advice would be greatly appreciated.
Thanks in advance for everyone's help!!
1- 75 101
2- 170 179
3- 0 0
4- 170 179
5- 75 79
7- 100 120
8- 0 0
9- 100 118
11- 0 0
12- 0 0
13- 170 179
14- 0 0
15- 185 185
19- 0 0
20- 0 0
21- 206 219
a1- 75 95
a2- 0 0
a3- 1.56 1.54
a4- 0 0
a5- 0 0
a6- 75 97
a7- 0 0
a8- 1.56 1.54
a9- 0 0
b1- 75 98
b2- 170 179
b3- 100 120
b4- 75 95
b5- 170 179
b6- 100 117
b7- 0 0
b8- 0 0
