Natural Sound
Active member
Grainger49 said:On the top board, along the top edge I see two almost spherical solder joints. I think that the solder pad didn't get much heat.
Look at the solder joints on the vertically oriented transistors. Some look just right but a few are again spherical. It doesn't join the circuit trace and the component lead well.
I'd reheat the ones that look too round.
Thanks Grainger. I had a feeling that was going to come up. The photo is deceptive. If I were to turn the board on edge you'd see that the solder joint is more like an inverted V than it is spherical. If anything they have too much solder. The "vertical transistors" are actually the LED's. And again are not accurately represented in the photo. That said I'll hit those again with a little heat.
This shouldn't be that hard. Four resistors have been replaced with four constant current circuits. I'm pretty certain that I got some bad parts. It happens, I've seen lots of examples of this in my 35 years in the electronics industry.
At this point I have two options. I can eat the $350 for the upgrade kit and put the FPIII back to stock. Or I can buy new components, rebuild the boards and start over at a later date.
Neither of these options are desirable but I'm out of options.
