Soft start kit alternate tubes
Yeah, if you're going down the interstage route, then the soft start driver board doesn't make a whole ton of sense.  You'll end up needing a ton of current and a reasonable amount of voltage, which would produce too much power across the C4S.
The Tango NC-20 is a 1:1 interstage.  The 45 has a mu of about 3 nominally, so you need a ton of step-up between the driver and the output if you want full power, or you need a third tube.
Then, you'll have to consider that interstage transformers typically don't go much above 30mA.  Since you want voltage step-up, you'll need to drive a low impedance with the 45 to accomplish that.  When you look at the 45 curves, then start drawing these steep load lines, things get pretty ugly in terms of distortion.
The one other option I can think of is to add two transformers to the circuit.  One would be something like the Sowter 8423 to sit between the 45 and 300B.  This IT will handle a lot of current, so you can get out of the nasty areas on the curves, but it won't give enough step-up.  To get the step-up, you'd also want an input transformer.  Without siting down to crunch the numbers, a 15k:600 wired with the 600 at the input will get you some additional voltage.  All of this working together will get you back in the ballpark of reasonable gain, but at the cost of:
Interstage iron: $420
Input transformers: $150-300
New chassis, layout, prototype time for quietest transformer orientation: ???
If you want all directly heated Paramounts, it's doable with 3S4's as pentodes or other various directly heated pentodes run as pentodes.
Thank you PB, that sounds like a lot of extra work but I'll keep it on the table. The 3S4 is a potential but I would like to rule out the triodes first. How about an odd duck like the 3c24? A nice red hot tube glow and a Mu of 25.
The 3C24 tends to enjoy some grid current, which means that one would want to use a gapped input transformer to make that work.
The EML30 will work just fine.  The nice thing about the EML30 is that it could be choke loaded right off the 300B high voltage supply without any issues.  (Maybe add an RC decoupling stage just in case)
Man that's an expensive tube!  Mind you, not as much as a pair if IT transformers but still ;)
Thanks for taking the time to bounce some ideas PB.  I've got a lot to think about.
Aaron, seems like we are wanting to go in the same direction.
I bought the proto-type Stereomour with the 3B7 DHT driver paired with my BeePre. I never get tired of listening to them. Tweaked Klipsch Heresy II and source is mainly internet radio through a squeezebox classic...improvements can be made on both ends.
I want to put a DHT driver direct coupled in my Paraglows, but after reading this thread, I know I don't have the knowledge. Best I can do is work off of a schematic.
I have the soft start kit on my bench with the boards populated. Probably what I end up settling with.
Robert
