galyons
I just finished a "Rescue Rebuild" on a Smash. The input, balance and volume pot wiring were a mess. Evidently the poor original builder tried a variety of alternative configurations and volume control devices. Sadly, he just never got it quite right and gave up. I wired back in the stock components, cleaned up some weird bits and pieces of wire remnants in several solder junctions. Ran the resistance and voltage checks, all good! Then I put it into my system in place of my much loved Foreplay 3EXT.
I left everything stock and listened for most of the day. I am MORE than pleasantly SURPRISED about just how good it sounds. Well done, PB!!!. My Foreplay 3X is configured for 3 6CG7's, has Teflon sockets, Grayhill switch, mono Welwyn stepped attenuators, Russian KBG PIO output caps and CMC silver plated copper RCA's. So I would consider it a pretty well maxed out Foreplay. The Smash is better...simply DHT magic into my Paramounts!!!
I just removed the balance pot and replaced the volume pot with a stepped attenuator. Even better!!!! I need to fabricate elevated platform mounts for the pair of KGB output caps. Then I will replace the stock output caps. But tonight I am just going to enjoy the music.
Doc said the Smash-up is the most audible of the preamp upgrades. If the Smashup is a bigger improvement then I saw with my Foreplay 1& 2 to C4s, Foreplay 3 to Extended, then.... I can't wait, (the Smashup has been ordered!). I have read many posts, in the various DIY audio forums, about how good the 4P1L tubes are run as triodes. Most of the builds have been relatively complicated circuits with OPT's, etc. PB showed, yet again, a simple, well designed circuit will rule the day!
There are two issues. Firstly, the well known 4P1L microphonics, ( not nearly as bad as my Quickie, BTW!). Switching channels or making contact with the aluminum plate does, indeed, set the 4P1L's to singing! So working on that!! Secondly, the Smash does not play well with my streamer, (Touch). The Smash picks up and injects into the signal a ticking, much like a mechanical clock. Very annoying. Solution, move the Touch up two shelves.
If you have been considering the purchase of a Smash...Do it!! So....the big QUESTION? When will the Smash-up ship?
Geary
Geary
