johnsonad
I'm happily listening to my modified SEX 2.1 (set up for Stax headphones) though the base is small given all that I've done to it and I'm thinking of moving to a 12x12" base to accommodate and clean it up some. With the base change this opens it up to other mods. Currently I'm running CLC in the PS using a pair of SEX 2.0 PF chokes and a film output cap in the finals. This made an audible improvement and I'm wondering if it would further improve with a shunt regulated power supply and DC on the filaments.
Here are some of the basic questions.
1. Can the 2.1 PS transformer handle converting to a shut regulated circuit in the present split design or would I need to move to a dual transformer circuit?
2. Given number one, would a VR tube be easier or go all the way and use a SEX C4S board and a separate shunt reg tube maybe in a CL configuration (I'll have the space for it)?
3. To add more complexity, I was thinking of swapping out the 6DN7 for a 6SN7 as I don't need the power as this is a headphone only amp and the Stax work on voltage swing anyway (100v P-P = 118dB). Maybe a single 6SN7 for the driver for both channels allowing for tube rolling and a single 6SN7 GTB for the output for both channels.
4. And then some DC for the filaments to help lower the noise floor even further though, with the larger chassis, this may remove any residual hum that's there.
Thoughts? Is it worth the effort? Thanks guys!
Aaron
Aaron
