Hi,
I am new to this forum, therefore I am sorry if I am posting something that has already been posted.
I got my crack and built it up. I then checked all the resistance readings and they were all perfect. I then powered it up, and the heaters glowed perfectly. So then I went to do a voltage check. I had my brother hold the negative lead to joint number 12 and tested the rest with my right hand. My brother slipped and the probe touched the 12 and 13 terminal simultaneously, discharging the capacitor with a large spark. There is now a large silver area on the resistor between 12 and 13 (photo attached). Also the fuse is blown. What should I do (apart from get a new fuse)? Is the resistor done? After doing some resistance checks, the place where it should be 0 (grounds) were all higher than 1. Please help!
Thank you,
Alex
Thank you,
Alex
