It very likely may, but finding a different resistor of the same value will be tough, and the stock part is a good quality metal film resistor to begin with.boulos said:Would it make a difference to change the Rbias resistor?
This kind of goes with what's above. The inductive vs. non-inductive selection isn't so important here, but finding a compact wirewound resistor of the appropriate value isn't going to be easy.boulos said:If so, would a wirewound resistor be desirable? Does it need to be non-inductive?
Just because I think it's interesting, here's what is (I think!) the technical story. The low-voltage winding doubles as an electrostatic shield for the adjacent high voltage winding, so the high AC voltage is capacitively coupled to the low voltage winding. The LV center tap is grounded to the chassis. But the rectifiers disconnect the LV supply from the winding itself, except for the short interval every cycle when they charge the 10000uF capacitor. Thus the heater can drift away from ground (probably due to heater-cathode leakage current)during the disconnect period of 1/120 second. Then when the diodes conduct momentarily the heater gets yanked back to ground. This fluctuating heater voltage is coupled to the cathode through heater-cathode leakage and capacitive coupling. The cathode is just as sensitive as the grid, so any hum at the cathode is amplified just like an input voltage.mcandmar said:For me the heater supply mod made the most difference to hum. In theory the supply is already referenced to ground via the center tap on the transformer, but in practice centering the supply at the DC side is still required. I also tried doubling the capacitance of the heater supply to half the ripple which made very little difference so its purely as ground reference issue imo.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
