seduction pre amp quit working
Hello,
You will need to be more definitive as to the problem then "quit working".  What is not working? Is it plugged in, fuse blown, getting power to the transformer?  Are the tube filaments lighting?
Get out your DMM and run the voltage checks:
Seduction Voltage Checks
Terminal          Voltage
6          6.5VDC
7        0VDC
9        6.0VDC
10        0VDC
11        0VDC
12        135VDC
14        0VDC
15        148VDC
16        0VDC
20        0VDC
25        160VDC
26,36      0VDC
27,37      70VDC
28,38        0VDC
29 ,39      70VDC
30 ,40      70VDC
34,44          135VDC
35 ,45          0VDC
A1,B1        70VDC
A2,B2          0VDC
A3,B3        1.6VDC
A4,B4        0VDC
A5,B5        6.0VDC
A6,B6              70VDC
A7,B7            0VDC
A8,B8            1.6VDC
A9,B9        0VDC
Let us know the results.
Geary
terminal      voltage
6                  9.4
7                    0
9                  5.46
10                  0
11                  0
12                178
14                  0
15                177
16                  0
20                  0
25                  178
26,36            these two bounce all over the place and the L.E.D.'s come on when i check here
27,37  starts high then goes down to 73.1 when LED's come on ,178 led's dont come on when i check here
28,38              0
29,39            177
30,40            bounces around a lot 70 and up
34,44            178
35,45              0
a1,b1              68.6, bounces around 90's up to low 100's one led blinks
a2,b2            .03, bounces around 1
a3,b3            1.49
a4,b4            9.6,9.61  led's have gone out at this point
a5,b5            10.4
a6,b6              178
a7,b7              0
a8,b8              .003,.007
a9,b9              0
at this point nothing seams to turn the leds back on
You have a flaky solder joint making an intermittent connection.
I can no longer get the leds to light any suggestions as to whare to start looking for this bad solder i dont have a schematic for this
