Grainger49
Hum/buzz is a hard problem to find. Sometimes inverting the power plug on one device cures it. Did you try shorting plugs, the above post includes a link?
Caucasian Blackplate said:A wooshing sound is tube rush, which is generally a normal operating condition. I'm guessing that the hum went away when you inserted the shoring plugs?
We never did hear which arm you have on your turntable. Often times Sota turntables ship with Rega arms, can you confirm?
fullheadofnothing said:The Ortofon 2M series of cartridges have a metal screw on top that is there to ground the cartridge to the arm. In practice, this causes more problems than it solves. You can try not using the arm's ground wire, which might eliminate the ground loop. If that doesn't solve the issue, you can put an insulator between the top of the cartridge and the arm, or replace the cartridge. Both of these will require the skills to mount a cartridge.
Wooshing sound is probably tube rush. Are you testing at higher than normal listening levels? If not, try another set of tubes.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
