Seduction build query
As far as the painted plate is concerned just make sure you polish or grind off the paint where the parts attach to it particularly the grounds and terminal strip mounts as the centre terminals are grounded to the chassis. If you have something like a Dremel tool the cleaning of these points is easy with a grinder or wire brush attachment. If you are concerned about numbering you can get a white or silver coloured pencil from an art supply store or a fine tipped paint pencil from a hobby shop. They work fine. Also you can get white grease pencils and just sharpen the point a bit.
Cheers
Sam,
I just PMd you that I painted both sides of my Seduction plate.  I used a Dremel tool (good excuse to get one, every man should have one) with a wire brush to remove the paint around all the screw holes.  It works fine, no noise.
Grainger
Grainger49 said:
Sam,  (Simultaneous post with mchurch)
Grainger
OK, I'm done with the build. Resistance readings all look good, except for A3/B3 which is 25.96M/21.10M (should be 1Meg+) and A8/B8 which is 23.26M/26.92M (should be 1Meg+).
Are these readings 20-MEG?, and is that OK?  Wiring seems to be fine, and sliver strip on LEDs in facing the right way.
"1meg+" means it's only a problem if it's less than 1meg.
Actually at those points you are measuring the resistance of the LED, using a voltage that (depending on your meter) is too low for it to conduct. Different meters will give different results; if you get a low value (a few K ohms) and the LED lights when you test it, you are probably still OK.  :^)
Thanks, everything else tested out great.
And it sounds great. Only thing is that I'm getting a strange pitter-pattering sound in the right channel only. It's barely audible at low volume, but when I crank it up (as I like to do), it's definitely audible, especially with cans on.
I don't recall hearing this sound with my other pre-amp, so I don't think it's the 'table. And it's definitely not my amp (the SEX). What could this be?
UPDATE: the interference is coming from the room somewhere. When I lift the Seduction up it goes away. It's something coming through the desk I have it on. Will have to experiment with placement, etc.
The pitter-patter sound might be an RF interference.  You have the tube shields in place, right?  Is there a phone or computer (today the same thing) close to the Seduction?
Try jumpering in a pair of the 200V 0.1uF KK Teflons.  Just use RS cheap jumpers so they can be removed and inserted easily.  Just lift one lead on each cap.  Remember there are voltages there that can HURT you.  The insulator on the alligator clip will protect you if you don't touch the conductors.
Swap tubes, see if it moves with the tube.  I would think that outside interference into the amps ciruitry itself would show itself in both channels.  So make sure it isnt the tube itself.
