S.E.X. 3 Build (pre-C4S) Blowing Fuses
burgerbassist
Hi All,
I purchased a S.E.X. 3 kit a while back and the build went swimmingly through the "Glow Test" on p.39 (tubes turned on as expected).  Then, I finished up the amp, passed resistance checks, and when I went and plugged the amp into the wall to do voltage checks it immediately fried the power fuse.
I've visually inspected and can't see anything that really sticks out to me as problematic - is there anywhere specific anyone would recommend starting to investigate power fuses blowing immediately upon power-up?
Dan
Here you go!  Let me know if there's anything you'd like to see closer.
It looks like that's where the issue is - I accidentally soldered to 36U and 34L instead of 36U and 33L.
After I get it fixed, do you think this mistake likely has the potential to have caused larger issues that I may have to track down and fix?
