Adrian
I just completed the build and carefully checked each wiring point, visually checked solder connections (I know that may not mean anything), took resistance readings, and voltage readings.
All resistances are almost exactly per check sheet values.
Tube filaments light equally.
All voltages are also right on expected values (my line voltage is 123.1VAC) EXCEPT:
A/B 7 ... -2.53/-2.52VDC vs. -3.15 (20% less)
A/B 8 ... 3.63/3.62 VDC vs. 3.15 (15.2% more)
These values place 6.15VDC across the filaments (nominal value of 6.3VDC).
C1 ... -2.57VDC vs. -3.15 (18.4% less)
C2 ... 3.66VDC vs. 3.15 (16.2% more)
C4 ... -2.56VDC vs. -3.15 (18.7% less)
C5 ... 3.86VDC vs. 3.15 (22.5% more)
C-Terminal voltages are consistent with the tube filament voltages.
I don't thnk these individual readings are a concern because the filament voltage is only 2.4% below nominal.
Is this correct or should I be concerned?
Also, I am now carefully checking all solder connections (re-solder if doubtful) because I have a bee-buzzing noise of constant volume regardless of pot setting coming out of the left channel with the phone jack fully inserted and half-volume buzzing out of both channels with plug inserted half-way.
