S.E.X. 2.0 iron upgrade kit now available
So, it is looking that one will still have to configure the new iron as an autoformer -- is this a correct assumption?  If so, I'm also guessing that balanced mode would not be possible with that configuration.
There is indeed a manual for the kit.  If you PM me your e-mail address, I'll send you a link so you can download it.
Yes, blue and red for the #45, with heatshrink over the black wire.
As far as the impedance goes, you will want to use the OT-2 transformer, but not quite as-wired in the SEX.  The SEX amp uses the transformer to provide an ~8K reflected load to the plate of the output triode, while the Paramour wants to see 4K.
Consequently, for something like an 8 Ohm Orca, you can wire the OT-3 transformer for 16 Ohms to reflect the correct load.
Got it, thanks!
Along the same lines as Tom's questions -- can the opt be configured for 4k primary and 16 ohm secondary?
Jim
Ok, now on to the plate chokes... will these new plate chokes work as ps chokes in the paramour -- 2a3 or 45, and would they be an upgrade over the triad c7x?  Gears are turning.
The C7-X has 10H of inductance, the upgrade iron has 20 or 40H, depending on the tap used, so I would use the C7-X for power supply duty.
The plate chokes are 2 or 3 times the resistance of the C7-X, so they drop more voltage. And they are designed to handle the output tube plate current. Of course they handle some AC current as well, so they can handle a bit more DC as long as the AC is small (i.e. not in a choke-input filter). At first glance the temperature rise looks OK.
Thanks, Paul, just an idea and I really didn't know the Rdc specs for the various chokes except the c7x, which every bottlehead probably knows is 270 ohms ;-).
Another opt question: is there a way to configure the opt for an 8 ohm load with a primary closer to 5k, instead of 4 or 8?  I knew there are some intermediate taps in there somewhere but no idea what they are.  I'm seriously thinking of putting this opt in the sr-45 as the nickel with the 45 tube seems to be just a bit too sweet.
Thanks Paul, but after thinking about it a bit I decided that I really didn't want to back myself into the 16 ohm speaker category.
