denti alligator
I’m replacing the parts Paul recommended to replace on the right side. As I’m doing so I’m seeing something that seems to me the obvious source of that green stuff: the 0.15ohm 3 resistors on the socket. They have a primarily green color, are right there where the green stuff was found, and I’m seeing that tiny bits of the outer green part of the resistors has chipped off. It’s the same green color that was there. Could I be that I put too much heat on those and the outer part (what’s it made of) “melted†down onto the socket?
Could these resistors be damaged in some way? They are not among the parts you told me to replace.
I’ll report back later, once I’ve switched everything out.
