Yes, they are the same part from different manufacturers.
and on reply 12 I stated that the resistor next to the capacitor on the B side started to smoke as I checked the voltages. Could this be what you are talking about? I also used my continuity checker on my multimeter and it says that 34U and IB are connected. Thanks for your help as always.Paul Birkeland said:IB is fed from a high voltage node in the power supply. If that node is pulled to 0V, you will burn up resistors pretty much immediately and you'll know there's a problem. Since you haven't reported that this happened, you either do not have IB connected to the correct spot, or that wire is broken.
Which resistor? Which terminals does it connect to and what's its value?thoven0215 said:I stated that the resistor next to the capacitor on the B side started to smoke
We use essential cookies to make this site work, and optional cookies to enhance your experience.
