Sp33ls
So, I've not had the best of luck recently with my kits :-[
When I went to paint the bell end of my Crackatwoa, I noticed shortly afterwards that a hum in the right channel would appear. After checking ground connections and tightening the nuts, it'd be intermittent.
After removing the paint around the top of the bell end holes, I checked with a DMM on the bottom side of the bell end, and it says I have a solid connection to ground for the bell end.
I passed all of the resistance checks.
But, more recently I noticed that I can reproduce the hum by pushing on the transformer, and now the right channel signal is either nonexistent or when it is present, the low-end seems to be quite muddy.
Also, the type of tube seemed to have an impact. My 6SN7's didn't have a right-channel, but my 12AU7's did, but some were muddier than others.
When doing the voltage check, now one side of the high-current boards doesn't have the LEDs light up, and one half of the low-current boar doesn't either. I also noticed that one of the LED's under the driver also doesn't light up now.
I've checked solder joins and loose connections, and have re-soldered suspicious joints, but nothing.
Any advice? I'm pretty bummed because I just picked up a nice pair of ZMF Atticus, and they sounded phenomenal for a little bit, but then I began to notice these issues.
