The issue is resolved. The problem: the ground lug wasn't tight. I tightened up all the bolts (transformer bolts need some tightening also), and all the terminals at the transformer bolts now read 0 ohms. It passed the voltage checks as well, and sounds great!
- Greg
- Greg
For the Crack 1.1, I pass all the resistance checks on page 47 of the manual, with the exception of terminal 22. It should be 0 ohms, but I get 2.3 ohms. There is nothing connected to terminal 22, other than one of the transformer bolts. FWIW, the other terminals connected to transformer bolts, 11, 16 and 17 read 2.0, 1.2, and 1.8 ohms, respectively.
Is this a problem or do the values fall within acceptable limits? If it is a problem, and ideas where to start looking?
Thanks in advance,
Greg
