I found a couple micro nicks on the blue twisted pair. Unfortunately, cutting down to clean wiring made the blue wires too short. So I had to very carefully de-soldered and replaced the entire run of cat 5 cabling to the selector switch and RCA. I gave myself another 1/4 inch on the cable run so it wasn't so tight a fit and was extra careful installing and soldering those back in place.
I'm now measuring 39.5K ohm on terminal 1 and 5 with either input selected. All resistances check out. Voltages check out. tubes are dialed in at 145V.
AWESOME! So, I am totally operational now. Thank you so much for the help PB!! You saved me many hours of trying to figure this all out, and I very much appreciate it.
It is sounding great. So far, I hear a little less bass extension than with my Lyr+ amp. But the clarity and detail of the mainline is amazing. There is a lot of high end attack, but well rounded at the same time. A very wide sound stage with excellent instrument separation that is especially noticeable in busy and congested parts.
I am using HE1000 stealth cans which I believe are 32 ohm. The mainline definitely pushes those as hard as I need it to. I was a little worried, given the low impedance and these headphones can be a little power hungry. I do get close to max volume for some songs, but 0db would be too loud for my ears.
I'm already wondering about upgrading the coupling capacitors now.... How long would you guys say the Dayton's took to fully break in? I don't want to mess with capacitors until I have some time on the stock mainline and it's fully broken in.
