AndTheCookies
Hello everyone.
I just completed a build of the Bottlehead Crack. I am at the point of checking resistance, and I have some very basic questions:
- When checking the terminals that are supposed to say 0 OHMS, my voltmeter does say "0.00" at first, but then it will fluctuate between "0.01" and "0.03," and not any higher. Is this a problem?
- The instructions say terminal 13 should climb "toward" 270k OHMs. Mine gets to 130k tops and no higher. Is this OK?
- Where it says to measure the RCA "ground lug," is that just where the black cable braided with the right and left channels terminates? So the two ground tabs at the RCA connectors? No?
- The RCA center pins just means measure the cable where it feeds into the RCA connectors, right?
Sorry if these are dumb questions. I'm kind of nervous about doing the electrical check next, so I really want to make sure everything is 100%. Thanks!
