resistance check T41 vs. T42
mete
Member
On page 68, it writes "Wrap the lead that passes through terminal 42L around and into 41L. You do not need to solder 42L.".
On page 110, in the resistance check table, T41 should be 22 ohms, T42 should be "*". Not surprisingly I measure 22 ohms at T42 as the lead touches to T41. Is this a mistake or is 22 ohms considered as "not close to 0" ?
We're saying that you don't need to worry about that terminal. We wrap the lead around to get the lead spacing right. There's nothing else attached to it so you don't need to measure it. It's why we say you don't need to solder it.
Yes I get that but as it is marked "*" and "*" means to double check that it is not close to 0, I guess one will/has to measure it just to be sure it is not shorted to somewhere else.
