debk
I put a Triad C-7X choke into my Eros.
Fairly easy to do, just had to drill two holes, remove the resistor and solder in the two leads. I also ran a ground wire from a solder lug I placed on one of the screws to the star ground lug on the power tranfo.
It did make a large difference in the sound. It sounds "brighter" and maybe more detailed now. I originally had a rear firing super tweeter on top of the speakers to add "a little twinkle to the high end". After the choke was installed I disconnected the super tweeters, it was just to bright. I may try and add a L-pad to the super tweeters to tone them down a bit, or play with the capacitor connected to them.
No problem with any 60Hz hum being picked up.
First impression is that I like the way it sounds with the choke.
Debra
Debra
