OverAnalyst
Thought it would be better to start my own troubleshooting post/topic instead of using someone else's.
Here's what I posted previously (yesterday morning):
Here are my resistance measurements for the following terminals:
38 - 7.7ohms (should be *)
39 - 1.1kohms, not fluctuating (should be *, but per the previous reply, if not 0, should be okay?)
41 - same result as 39
42 - same result as 38
For the following, I get very similar to Neuronal, so I’m assuming they’re ok?
45 - * (should be 0 ohms)
46 - .7 ohms (should be OL)
47 - * (should be OL)
And assuming those resistance values are okay, I went ahead and proceeded with voltage checks. Here are my off-nominal readings:
44 - 78V (should be 180V)
45 - 77 V (should be 0V)
47 - 175V (should be 0V)
The manual I’m using is dated 7.21.19
So I plugged her in, and instead of music, I get a hum on both speakers. The tubes do light up (so did the LED’s when doing the voltage checks). I tried the different line source selections on my preamp, and still humming. Photos below. Know the issue?
